TomDesign Posted February 26, 2016 Share Posted February 26, 2016 I would like to build a decorative stone arch above a garage door. This would have the stones placed vertical in a low arch over the double garage door with horizontal stones going up the right and left of the door and extending above the arch. I searched and did not see how to do this. Any links or hints/instructions would be appreciated. Link to comment Share on other sites More sharing options...
solver Posted February 26, 2016 Share Posted February 26, 2016 I've used a lintel, and casing that is larger than normal here. Just changed the materials to brick. You may not need the lintel, i wanted something to be proud of the casing. You should be able to do the same with whatever material you choose. Link to comment Share on other sites More sharing options...
TomDesign Posted February 27, 2016 Author Share Posted February 27, 2016 How would one bend the lintel into an arch shape? Yes, it would need to be proud of the rest of the wall, but only by about 2". I don't remember seeing a lintel in the program, but it makes sense there is one. Link to comment Share on other sites More sharing options...
DavidJPotter Posted February 27, 2016 Share Posted February 27, 2016 Here is a You Tube video of me creating an arched lintel in Home Designer Pro: https://youtu.be/4ZaX_4SIBnc DJP 1 Link to comment Share on other sites More sharing options...
katalyst777 Posted February 29, 2016 Share Posted February 29, 2016 Unfortunately, the main article I found on creating a soldier course with steps for an arch only applies to Chief, so I suspect the best we can do in Home Designer is to import something similar. KB-00888: Importing 3D Symbols https://3dwarehouse.sketchup.com/model.html?id=e0e7891e1cdc1cb1ee29c5eb674fb095 3 Link to comment Share on other sites More sharing options...
