English Posted February 3, 2016 Share Posted February 3, 2016 According to Pella their 3D files are only available as an ADM (Revit) file. Is it possible to import an ADM file so I can get Pella windows in 3D view?ThanksAlan Link to comment Share on other sites More sharing options...
solver Posted February 3, 2016 Share Posted February 3, 2016 Can't answer your question, but there is a Pella catalog available for Chief. Maybe they will someday make this type of catalog available to Home Designer users for a nominal fee. Are you looking for something unique that you can't simulate with a stock window? Link to comment Share on other sites More sharing options...
solver Posted February 3, 2016 Share Posted February 3, 2016 All I could find on the Pella site were .rfa files. From Chieftalk: Toto only supplies *.rfa models, which are Revit native and not importable to CA. Try searching Trimble 3D Warehouse for an skp or dae file of the fixture you're looking for. You my also ask somebody here to open the rfa file in 3ds Max and export as 3ds or obj for import to CA. Marvin is good to supply Home Designer compatible files. Link to comment Share on other sites More sharing options...
DavidJPotter Posted February 3, 2016 Share Posted February 3, 2016 In Home Designer Pro you can, Using only the window dialog box, emulate most windows on the market. You can look up the specifications of a particular window and using only the window specification duplicate all aspects of most windows on the market except the most specialized shaped custom windows. In the past I have downloaded libraries from Pella, Marvin, Andersen and others and found them completely redundant, just taking up space on my hard drive. I have since deleted them for that reason. You are free do to as you wish. DJP Link to comment Share on other sites More sharing options...
katalyst777 Posted February 8, 2016 Share Posted February 8, 2016 Discussed in this earlier thread from December of last year.https://hometalk.chiefarchitect.com/index.php?/topic/1809-pella-windows/ As far as I can tell from the website, you'd need to upgrade to Premier to get the Pella catalog.https://3dlibrary.chiefarchitect.com/index.php?r=site/detail/856 You can probably create the same look though, just by modifying windows placed using the normal "Window" tool. (Whoops, didn't realize you were the same one who started this earlier thread on the exact same topic a couple of months ago.) 2 Link to comment Share on other sites More sharing options...
English Posted February 9, 2016 Author Share Posted February 9, 2016 Thanks Kat. I can't afford to upgrade to CA Premier so I guess I'm stuck with creating them myself as David suggested. I have a question though -- the Pella catalog is a CALIBZ file and I've imported that type of file many times so why can't I do that now? Thanks Alan Link to comment Share on other sites More sharing options...
katalyst777 Posted February 9, 2016 Share Posted February 9, 2016 Certain manufacturers choose to only make their catalogs available for the Premier version and not Home Designer, so my guess is that there's some kind of check to make sure those calibz files can't be used in a less advanced version. 1 Link to comment Share on other sites More sharing options...
English Posted February 12, 2016 Author Share Posted February 12, 2016 I was incorrect -- there is no Pella under Doors and Windows. Either the manufacturer asks CA not to let HD Pro users have access or CA decides not to. When I contacted Pella they said that they do not provide the calibz files for HD Pro. Alan Link to comment Share on other sites More sharing options...
