ArchieD Posted January 31, 2016 Share Posted January 31, 2016 My glass panel door for my shower enclosure appears like a solid wall in 3d, but in drawing mode, nothing but the panel appears. Why would this be and how can i fix it? Thanks!! Link to comment Share on other sites More sharing options...
DavidJPotter Posted January 31, 2016 Share Posted January 31, 2016 It depends upon what software title you have and your current material settings, what are they? Glass's transparency can be edited depending upon which software you own. It is also important as to which camera type you are using: Glass should appear transparent in a "Render Camera" and non-transparent in a "Vector View" camera view. Glass can be programmed to appear transparent even in a vector view camera in "3D Settings" depending upon which software title you actually have. What do you have?DJP Link to comment Share on other sites More sharing options...
katalyst777 Posted February 1, 2016 Share Posted February 1, 2016 You probably painted the "Room" using the Material Painter and that overrides the glass wall type's material. Follow the instructions in this Knowledge Base article to fix it.https://www.homedesignersoftware.com/support/article/KB-00556/restoring-default-materials-on-items-painted-with-the-material-painter.html Link to comment Share on other sites More sharing options...
ArchieD Posted February 2, 2016 Author Share Posted February 2, 2016 Thank you. Somehow my room is set up so that I could not treat each wall separately....instead each is following some "mother default". I did manage to get the glass to appear transparent. Am currently looking how to undo the "room" effect so I can treat each wall separately. Thanks for your help. Link to comment Share on other sites More sharing options...
LawB10 Posted February 2, 2016 Share Posted February 2, 2016 Use the break wall tool if you to want use a different material for each Choose Component or Object not Room Link to comment Share on other sites More sharing options...
katalyst777 Posted February 2, 2016 Share Posted February 2, 2016 On 2/2/2016 at 6:49 PM, ArchieD said: Thank you. Somehow my room is set up so that I could not treat each wall separately....instead each is following some "mother default". I did manage to get the glass to appear transparent. Am currently looking how to undo the "room" effect so I can treat each wall separately. Thanks for your help. See the article I posted previously to reset back to default, and keep in mind in the future that sadly, that's just how the material painter works on walls. You can't use the spray can in 3D views to change wall materials without it getting applied to the whole room. There's other ways to change the materials of a single wall though, discussed in this Knowledge Base article. KB-00071: Changing the Color or Material of a Single Wall From lurking on ChiefTalk, it looks like it's better in the public beta of X8 out now, where you can paint a single wall using the Material Painter, so fingers crossed that maybe we'll see this trickle down to the next version of Home Designer too. Link to comment Share on other sites More sharing options...
