FlightDeck Posted January 16, 2016 Share Posted January 16, 2016 Hi, I have a plan in feet/inches. Is it possible to switch to metric (mm) instead? Thanks, Link to comment Share on other sites More sharing options...
solver Posted January 16, 2016 Share Posted January 16, 2016 Look down 8 or 10 threads. Link to comment Share on other sites More sharing options...
Solution FlightDeck Posted January 16, 2016 Author Solution Share Posted January 16, 2016 Lol I actually searched for "change units" before posting and that thread didn't come up. At any rate I guess the short answer is no, it's yet another basic thing that Home Designer doesn't do. I'll just leave the model in ft and do any conversion calculations myself..., which, based on the scribbled notes on the metric blueprints, is exactly what the construction guys did as well. Thanks anyway. Link to comment Share on other sites More sharing options...
AlexYallop Posted February 10, 2017 Share Posted February 10, 2017 I am gobsmacked you cant just click between mm and inches..... Such a simple thing to be able to do! I even tried to make a new plan, with feet and inches, then copy my layout to the new plan, nope it does not like that either.... Not bad for a £500 app! lol Link to comment Share on other sites More sharing options...
DavidJPotter Posted February 10, 2017 Share Posted February 10, 2017 It helps if you read the "Reference Manual" section on Units and also this is explained fully in your "Users Guide" on how when you open a new plan is where you select "Metric Units or Imperial Units". Easy to do but afterwards you are stuck with whatever you originally chose. If you were to upgrade to Chief Premier it has the ability to "switch" between one unit or the display both. Your main barrier is your own not knowingness. DJP Link to comment Share on other sites More sharing options...
