FlightDeck Posted January 10, 2016 Share Posted January 10, 2016 Hi, how can I disable mouldings on individual walls in a room? For example if one of the walls in a room is brick and the rest are drywall, how do I get baseboards on the drywall walls (default) but NOT on the brick wall? Thanks and regards, Link to comment Share on other sites More sharing options...
FlightDeck Posted January 10, 2016 Author Share Posted January 10, 2016 ...my current workaround is using Room Dividers to create "virtual rooms" along the walls in question and then deleting the mouldings from the definitions of those virtual rooms. Was worried it would create strange geometries at the wall corners where baseboard meets no-baseboard, but so far it seems to look okay: Is there a more preferred way to do this though? Link to comment Share on other sites More sharing options...
solver Posted January 10, 2016 Share Posted January 10, 2016 Another missing feature, but you have a creative solution. I have used a Custom Backsplash over an entire wall and applied brick, stone etc. It will cut itself around doors and windows, although I only remember using it on walls without them. You can set a thickness to it just hides the base or other trim. 1 Link to comment Share on other sites More sharing options...
DavidJPotter Posted January 10, 2016 Share Posted January 10, 2016 Kyle, I believe you have discovered the ways available in Home Designer Pro. Chief Premier has molding tools to allow greater control over where moldings appear or not at choice, that and many other choices are available with Chief Premier or Chief Premier Interiors. DJP Link to comment Share on other sites More sharing options...
FlightDeck Posted January 11, 2016 Author Share Posted January 11, 2016 I have used a Custom Backsplash over an entire wall and applied brick, stone etc. It will cut itself around doors and windows, although I only remember using it on walls without them. You can set a thickness to it just hides the base or other trim. Cool idea, thanks Eric! Link to comment Share on other sites More sharing options...
katalyst777 Posted January 11, 2016 Share Posted January 11, 2016 If you mark a wall as "No Room Def" it will not pick up the moldings applied to the room. You might have to add a room divider to make room definition if you do this though, depending on the situation. 1 Link to comment Share on other sites More sharing options...
FlightDeck Posted January 11, 2016 Author Share Posted January 11, 2016 If you mark a wall as "No Room Def" it will not pick up the moldings applied to the room. You might have to add a room divider to make room definition if you do this though, depending on the situation. Interesting! But possibly tricky like you say. For example if it's an exterior wall... I'll experiment with this option. The "virtual room" workaround I used is sort of okay, however sometimes the mouldings are cut in odd ways. Your suggestions sounds like it might be a little tidier. Link to comment Share on other sites More sharing options...
