English Posted January 6, 2016 Share Posted January 6, 2016 The stairs down to my basement have an intermediate ninety degree section where the treads are pie shaped. How can I achieve that? I checked the knowledge base but all I can see is the ability to create a curved stair. Also how do I make the first two treads curved e.g where there is no side wall against the first two treads? Thanks Alan Link to comment Share on other sites More sharing options...
solver Posted January 6, 2016 Share Posted January 6, 2016 Research winders, or just use landings to make the pie shaped treads. Don't understand "how do I make the first two treads curved e.g where there is no side wall against the first two treads?" What's the issue? 1 Link to comment Share on other sites More sharing options...
English Posted January 6, 2016 Author Share Posted January 6, 2016 Eric Take a look at the photo. The bottom tread is wider than the other and has a rounded profile. Thanks Alan Link to comment Share on other sites More sharing options...
solver Posted January 6, 2016 Share Posted January 6, 2016 Make the bottom tread a landing. You can shape the edge like any other polyline. 1 Link to comment Share on other sites More sharing options...
Solution English Posted January 6, 2016 Author Solution Share Posted January 6, 2016 Make the bottom tread a landing. You can shape the edge like any other polyline. Thanks Eric. Alan Link to comment Share on other sites More sharing options...
FlightDeck Posted January 10, 2016 Share Posted January 10, 2016 Research winders, or just use landings to make the pie shaped treads. Aw geez I wish I had known this... I just bought Pro specifically so I could make winders. I didn't know that the landings could be reshaped in Arch version and their railings turned off/on on any side to make winders without the Pro version. Link to comment Share on other sites More sharing options...
LawB10 Posted January 10, 2016 Share Posted January 10, 2016 Or you could simply click on the starter tread tool, it does the same trick. Link to comment Share on other sites More sharing options...
