lianeanderson Posted November 15, 2015 Share Posted November 15, 2015 I can not seem to be able to find or create a frameless recessed medicine cabinet, which I use in almost all my design projects. Anyone have an idea for me? Thanks! Link to comment Share on other sites More sharing options...
DavidJPotter Posted November 18, 2015 Share Posted November 18, 2015 Part of the trick of doing niches and med. cabs is to cut a hole in the wall using a "doorway" with the casing turned off. Such an object (doorway with casing off) looks like a hole in the wall. Position the doorway and resize it for your purposes before turning the casings off (a doorway with casings off is almost impossible to select in camera views), the you place your wall niche or medicine cabinet in the provided hole in the wall. Of course such a hole provided for a niche or med cab leaves a hole on the opposite wall side that you fill with a thin soffit object to patch the unwanted hole. Just control-dragging a med. cab into a wall also works and leaves no opposite side wall hole but it does frame properly where the later method does not properly wall frame. DJP Link to comment Share on other sites More sharing options...
4ndrew Posted July 1, 2023 Share Posted July 1, 2023 Well, I'm here to ask the same question, 8 years later... Couldn't find a medicine cabinet today. Any updates? Link to comment Share on other sites More sharing options...
Garybills Posted July 2, 2023 Share Posted July 2, 2023 I don't see any medicine cabinets in any libraries. You can make one from a wall cabinet and use CTRL to position it in a wall niche. Change your cabinet door to a slab and the material to glass. Link to comment Share on other sites More sharing options...
Rookie65 Posted July 2, 2023 Share Posted July 2, 2023 There are several in the Kohler manufacturers catalog Link to comment Share on other sites More sharing options...
Garybills Posted July 2, 2023 Share Posted July 2, 2023 56 minutes ago, Rookie65 said: There are several in the Kohler manufacturers catalog Thanks Keith, I didn't have the Kohler catalog downloaded in my 2021. Link to comment Share on other sites More sharing options...
