belmont Posted October 6, 2015 Share Posted October 6, 2015 How do I remove the portion of the basement that is below the terrain line when I take an elevation? Or, can I do an elevation without even drawing a terrain perimeter? Link to comment Share on other sites More sharing options...
katalyst777 Posted October 6, 2015 Share Posted October 6, 2015 You don't have to have a Terrain Perimeter at all in order to create an elevation.You can turn off the whole "Foundation" layer (but that will turn off the display of everything on Floor 0 in the elevation view).You can leave the Terrain Perimeter, but just turn off its display in the Elevation.Depending on your version, you might even be able to create a CAD object to mask just the part of the foundation below the terrain. Link to comment Share on other sites More sharing options...
belmont Posted October 7, 2015 Author Share Posted October 7, 2015 I'm using HD Pro 2014. The problem with turning off the foundation layer is that it looks funny in the elevation. Say the house is out of the ground about 24", so I have steps coming off the front and back door. How do I show the 24" of foundation that is above ground without showing what is below ground? Link to comment Share on other sites More sharing options...
Solution solver Posted October 7, 2015 Solution Share Posted October 7, 2015 See image. Link to comment Share on other sites More sharing options...
belmont Posted October 7, 2015 Author Share Posted October 7, 2015 Thanks. Link to comment Share on other sites More sharing options...
LawB10 Posted October 7, 2015 Share Posted October 7, 2015 You could also fool around with the Terrain Perimeter. Click on it and open it, then uncheck "Automatic" the higher the number(s) the lower the Pad goes. Link to comment Share on other sites More sharing options...
