How do you dulicate a building?
ChrisO
If you need to make a copy of a building within the same plan, you can use the "Edit Area" tool (Edit - Edit Area) to copy single story buildings into the same plan file. For multi-story buildings you would have to copy other floors than the first floor using "Edit Area" but manually one floor at a time. This is true in all titles except Home Designer Pro that additionally has an "Edit Area All Floors" command that other Home Designer titles do not have. DJP
  • 5 years later...
