BSEagle Posted June 28, 2015 Share Posted June 28, 2015 I cannot get Home Designer Suite 2015 to draw my gable roof correctly. We have a prow on the front of the design and the program keeps drawing the gable incorrectly. The gable starts correctly on the outside walls but then dips back down at the center of the prow, creating two gables instead of one. How can i correct this? Link to comment Share on other sites More sharing options...
solver Posted June 28, 2015 Share Posted June 28, 2015 Posting an image of what you are trying to model will help us. Link to comment Share on other sites More sharing options...
DavidJPotter Posted June 28, 2015 Share Posted June 28, 2015 Solver, he did post an image (see above). I did try to create a prow roof myself in Home Designer Suite 2015 and was not able to. It may be possible to do but I could not do it. It is easily done in Home Designer Pro or Chief Architect Premier. Perhaps someone else might find a workable answer but I could not. You can only mark those walls Full gable or High Shed Gable at a time but the latter gets the effect you want. DJP 1 Link to comment Share on other sites More sharing options...
Jo_Ann Posted June 28, 2015 Share Posted June 28, 2015 http://www.homedesignersoftware.com/support/article/KB-01197/52/Home-Designer/Roofs/Creating-a-Prow-Roof.html 4 Link to comment Share on other sites More sharing options...
Kbird1 Posted June 28, 2015 Share Posted June 28, 2015 Did you mark the walls of the Prow Full Gable , instead of High Shed/Full Gable ? been a while since I did one but I think that was the trick Link to comment Share on other sites More sharing options...
DavidJPotter Posted June 28, 2015 Share Posted June 28, 2015 Mick is right, you have to mark the two prow walls-roof tab "High Shed Gable" and it then works like a charme! DJP Link to comment Share on other sites More sharing options...
BSEagle Posted June 30, 2015 Author Share Posted June 30, 2015 thank you! the High Shed Gable worked and now my roof is correct. Thank you. Link to comment Share on other sites More sharing options...
