Robborito Posted April 17, 2025 Share Posted April 17, 2025 I've attached a plan file underway on a dwelling/house; Actually - file is more than 14Mb - so I can email it direct to anyone who is interested..... The third image below shows the current plan file camera 2 view and these subject wall, beams and posts and balustrade panels that have moved; Also included two previous images before what is now happening with a wall, floor and balustrade objects; If you view Camera 2 to locate the yellow wall - it needs to be deleted but remains and wont be deleted; I have no idea where it has come from. This yellow wall. And the 2nd floor balcony is a mystery also. I can usually sort these things out but this has me bamboozled....mystified... Any suggestions or instructions please would be greatly appreciated Thanks. Jeff. Link to comment Share on other sites More sharing options...
scottharris Posted April 17, 2025 Share Posted April 17, 2025 That's likely an automatic attic wall that is being generated due to an issue from the floor below. You can turn it off. Link to comment Share on other sites More sharing options...
Robborito Posted April 17, 2025 Author Share Posted April 17, 2025 52 minutes ago, scottharris said: You can turn it off Thanks Scott, but it still remains having tried that. Any more suggestions? Happy to forward my plan file for your perusal? Jeff. Link to comment Share on other sites More sharing options...
y-g-m-n Posted April 17, 2025 Share Posted April 17, 2025 select wall. OPen up the wall editor thingy. See what if ATTIC wall is not checked. or take screen shot and post. Link to comment Share on other sites More sharing options...
scottharris Posted April 17, 2025 Share Posted April 17, 2025 If the plan is too large to post, do you have a cloud you can copy to and post a link? You can also send the file into our support group. Link to comment Share on other sites More sharing options...
Robborito Posted April 18, 2025 Author Share Posted April 18, 2025 OK - when everything else fails - think 'Rooms'; everything on the floor plan is based on configured rooms - correctly. Seems my balcony was not configured correctly with balustrades etc. as a room and hence once I fixed that, everything else worked perfectly - the way it should. So as for the unknown wall that would not delete - I simply have it hidden from view. Thanks. Link to comment Share on other sites More sharing options...
