Need Help with contemporary roof lines
CONTEMPoraryMan
Go to solution Solved by Jo_Ann,
I am having a hard time getting roof lines to work on my home design. It is a contemporary home with long sloping roofs overhanging. Maybe someone can mark up the attached screen shots to help me select the right walls that should be 'full gable walls' and which ones are 'high shed walls". Some walls are the high walls & gable walls in some instances. Is it even possible? did i read i can manually draw the roof?
sean
Home Designer 2023
12 hours ago, Robborito said:
I like your configuration of roof lines. Looks pretty good - not sure I get the issue though?
Jeff.
the outside pic is an rendering from an architect. I want to replicate in the home designer software, which seems difficult with tthe lower end version. One wall for instance is the top of the shed slope while also the downward slope of the other roof line
  • Solution
What you ask for on the forum, is too extensive for any in depth replies.
You need to watch the video tutorials, https://www.homedesignersoftware.com/videos/
and then practice and experiment until you understand how the software works.
That design is very complicated for someone new to the software.
To answer your question, "Is it possible?"
Yes.
And it CAN be modeled using only the auto build roof tools, that Suite and Architectural offer. :)
That is great to see, I have tried the videos, including some of the more indepth ones. I just need to find the right way without having to build multiple walls. Glad to see it can be done. I do have Home Designer suite 2023, so i hope you were able to do this in that program. I would pay a few $ via paypal for that design if i can load it into suite
Yes.
 any thoughts on sharing the file with me?
