CONTEMPoraryMan Posted April 16, 2025 Share Posted April 16, 2025 I am having a hard time getting roof lines to work on my home design. It is a contemporary home with long sloping roofs overhanging. Maybe someone can mark up the attached screen shots to help me select the right walls that should be 'full gable walls' and which ones are 'high shed walls". Some walls are the high walls & gable walls in some instances. Is it even possible? did i read i can manually draw the roof? sean Home Designer 2023 Link to comment Share on other sites More sharing options...
Rookie65 Posted April 16, 2025 Share Posted April 16, 2025 What version of Home Designer and year are you using? Filling out your signature will help people help you. Link to comment Share on other sites More sharing options...
Robborito Posted April 17, 2025 Share Posted April 17, 2025 11 hours ago, CONTEMPoraryMan said: a contemporary home with long sloping roofs I like your configuration of roof lines. Looks pretty good - not sure I get the issue though? Jeff. Link to comment Share on other sites More sharing options...
CONTEMPoraryMan Posted April 17, 2025 Author Share Posted April 17, 2025 12 hours ago, Robborito said: I like your configuration of roof lines. Looks pretty good - not sure I get the issue though? Jeff. the outside pic is an rendering from an architect. I want to replicate in the home designer software, which seems difficult with tthe lower end version. One wall for instance is the top of the shed slope while also the downward slope of the other roof line Link to comment Share on other sites More sharing options...
Rookie65 Posted April 17, 2025 Share Posted April 17, 2025 Again, which version of the Home Designer software do you have, Suite, Architectural, or Pro???? Link to comment Share on other sites More sharing options...
Solution Jo_Ann Posted April 17, 2025 Solution Share Posted April 17, 2025 What you ask for on the forum, is too extensive for any in depth replies. You need to watch the video tutorials, https://www.homedesignersoftware.com/videos/ and then practice and experiment until you understand how the software works. That design is very complicated for someone new to the software. To answer your question, "Is it possible?" Yes. And it CAN be modeled using only the auto build roof tools, that Suite and Architectural offer. Link to comment Share on other sites More sharing options...
CONTEMPoraryMan Posted April 17, 2025 Author Share Posted April 17, 2025 That is great to see, I have tried the videos, including some of the more indepth ones. I just need to find the right way without having to build multiple walls. Glad to see it can be done. I do have Home Designer suite 2023, so i hope you were able to do this in that program. I would pay a few $ via paypal for that design if i can load it into suite Link to comment Share on other sites More sharing options...
CONTEMPoraryMan Posted April 21, 2025 Author Share Posted April 21, 2025 On 4/17/2025 at 1:53 PM, Jo_Ann said: What you ask for on the forum, is too extensive for any in depth replies. You need to watch the video tutorials, https://www.homedesignersoftware.com/videos/ and then practice and experiment until you understand how the software works. That design is very complicated for someone new to the software. To answer your question, "Is it possible?" Yes. And it CAN be modeled using only the auto build roof tools, that Suite and Architectural offer. any thoughts on sharing the file with me? Link to comment Share on other sites More sharing options...
Jo_Ann Posted April 21, 2025 Share Posted April 21, 2025 Here is another snip pic of the house. This is only meant to be an example, to show you what you can create with your software, (with practice and experimenting). I did not save the plan file. 1 Link to comment Share on other sites More sharing options...
