DerwoodKevin Posted April 19, 2015 Share Posted April 19, 2015 The standard room for kitchen design is aligned vertically with open space on either side so I have to scroll up and down to view it. It would be so much easier to use if I could rotate it 90 degrees. Is there a way to rotate the whole room 90 degrees? Link to comment Share on other sites More sharing options...
Kbird1 Posted April 19, 2015 Share Posted April 19, 2015 you don't say what version you have ? but some versions have a "rotate Plan" option on the Tools menu Link to comment Share on other sites More sharing options...
DerwoodKevin Posted April 19, 2015 Author Share Posted April 19, 2015 Thanks. I have Home Designer Suite 2016. Link to comment Share on other sites More sharing options...
solver Posted April 19, 2015 Share Posted April 19, 2015 If you have Edit>Edit Area, you can marquee around what you want to rotate and then rotate everything selected. Sometimes when rotating via Rotate Plan, the arrow keys will not work as expected -- pressing the right arrow will result in a up arrow action, for example. Link to comment Share on other sites More sharing options...
DavidJPotter Posted April 19, 2015 Share Posted April 19, 2015 Suite 2016 has an "Edit Area" tool ( Edit - Edit Area) and also a "Reverse Plan" command (Tools - Reverse Plan). It would be smarter just to redraw the kitchen facing the way you are most comfortable with as opposed to those command tools but you do what seems right to you and live with the results. DJP Link to comment Share on other sites More sharing options...
Kbird1 Posted April 20, 2015 Share Posted April 20, 2015 If you have Edit>Edit Area, you can marquee around what you want to rotate and then rotate everything selected. Sometimes when rotating via Rotate Plan, the arrow keys will not work as expected -- pressing the right arrow will result in a up arrow action, for example. I had forgotten about the arrow key/scrolling issue with using Rotate Plan , so yes I'd use Eric's suggestion of Edit Area and rotating the whole plan. Link to comment Share on other sites More sharing options...
