PhilCrane Posted October 20, 2024 Share Posted October 20, 2024 When I set a room type it displays the dimensions of the room but this does not agree with the dimensions shown by the Interior Dimensions tool, they are 1" smaller on each axis. I assume this is because the room type display is measuring the room from drywall to drywall and the dimension tool is measuring from framing to framing. Is there a way to change the way the interior dimension tool measures so that it is drywall to drywall? Link to comment Share on other sites More sharing options...
solver Posted October 20, 2024 Share Posted October 20, 2024 Tip: Always say what title and year (Pro 2020, Suite 2023) you are using. Check your Defaults for dimension settings. You may select the dimension and manually reposition the end points to the surface. Link to comment Share on other sites More sharing options...
PhilCrane Posted October 20, 2024 Author Share Posted October 20, 2024 Thanks. I'm running 2025 HD Architecture. I have tried changing the default dimensions "Locate Wall Dimensions At" from Main Wall Layer to Surface but, so far as I can see, this makes no difference to any measurement. What's the difference? Link to comment Share on other sites More sharing options...
y-g-m-n Posted October 21, 2024 Share Posted October 21, 2024 room dims are from the sheetrock. Interior dims go to studs for framers so will be 1" longer than room dims if each wall has1/2" sheetrock room dims are generic for people looking at plans do decide if they want the plans. Interior dims are for construction Link to comment Share on other sites More sharing options...
JMoldenhauer Posted October 26, 2024 Share Posted October 26, 2024 On 10/20/2024 at 2:28 PM, PhilCrane said: Thanks. I'm running 2025 HD Architecture. I have tried changing the default dimensions "Locate Wall Dimensions At" from Main Wall Layer to Surface but, so far as I can see, this makes no difference to any measurement. What's the difference? did you find a solution for this? Link to comment Share on other sites More sharing options...
JMoldenhauer Posted October 26, 2024 Share Posted October 26, 2024 I cant seem to find how to make the wall build tool account to exterior material on the ends. So if want a 26" wall exterior corner to exterior corner the system is not adding the wall end of material (stucco) What am I missing? home designer pro 2024 Link to comment Share on other sites More sharing options...
Rookie65 Posted October 26, 2024 Share Posted October 26, 2024 Change it to dimension from surface and not wall dimension layer, if Architectural lets you set dimensions that way Link to comment Share on other sites More sharing options...
solver Posted October 26, 2024 Share Posted October 26, 2024 2 hours ago, JMoldenhauer said: did you find a solution for this? The solution is above in my response. And almost always best to start a new thread when asking about almost anything. You are asking about Exterior Dimensions not Interior Dimensions. Link to comment Share on other sites More sharing options...
JMoldenhauer Posted October 26, 2024 Share Posted October 26, 2024 Been struggling with this for a couple days... I'm sorry but I do not see a solution in your response. I don't understand what I am missing. I have tried every dimension setting it allows me to and I cant get it to work as it says it will. 1-open default settings 2-double click dimension 3-under walls; select surfaces Do I have that correct? Link to comment Share on other sites More sharing options...
