VWCALBUG Posted October 9, 2024 Share Posted October 9, 2024 I'm not sure what this style is called, I can't find it in the library or additional downloadable libraries....how do I model this for 3D purposes? Link to comment Share on other sites More sharing options...
Rookie65 Posted October 9, 2024 Share Posted October 9, 2024 Have you downloaded the certainteed catalog? If so, go to siding>vertical >8" board and batten. Then edit the spacing to 12" or whatever it is. Make sure the texture changed too. Then paint it the color you need it to be Link to comment Share on other sites More sharing options...
VWCALBUG Posted October 9, 2024 Author Share Posted October 9, 2024 Awesome thank you, I haven't downloaded that catalog but I will! Link to comment Share on other sites More sharing options...
y-g-m-n Posted October 9, 2024 Share Posted October 9, 2024 just search board and batten as there are many of them in library from the basic HD library to manufacturers. Link to comment Share on other sites More sharing options...
Rookie65 Posted October 9, 2024 Share Posted October 9, 2024 Yes, you can do that. Yet I think it helps if you can reference a manufacturer that makes the product so you don't present something made up that may not actually be available. As not all of a manufacturers products are available in all areas. Link to comment Share on other sites More sharing options...
VWCALBUG Posted October 9, 2024 Author Share Posted October 9, 2024 How do I adjust the spacing of the batten? Link to comment Share on other sites More sharing options...
Rookie65 Posted October 9, 2024 Share Posted October 9, 2024 Open up the dialog box and you will see the spacing. Then adjust it Link to comment Share on other sites More sharing options...
VWCALBUG Posted October 9, 2024 Author Share Posted October 9, 2024 What dialog box? How do I get it to adjust all the walls on the plan? Link to comment Share on other sites More sharing options...
Rookie65 Posted October 9, 2024 Share Posted October 9, 2024 Open the wall type, click on the siding, then adjust it Link to comment Share on other sites More sharing options...
solver Posted October 10, 2024 Share Posted October 10, 2024 2 hours ago, VWCALBUG said: How do I adjust the spacing of the batten? Textures are just image files, so you are only scaling (stretching or compressing) the image. As you scale to make the spacing wider, you are also making the battens wider. There is no way to adjust the batten spacing independently of the rest of the image. Tip: Always say what title and year (like Pro 2020) you are using as suggestions/answers often depend on that info. Link to comment Share on other sites More sharing options...
y-g-m-n Posted October 10, 2024 Share Posted October 10, 2024 some of the manufacturers of it have 1 or 2 varieties - Cannot remember which but yo get choice like 6" or 9"spacing I forget actual numbers but remember seeing it. Or make it MANUALLY. Put up panels as wall exterior then either add custom backsplash or 3d shapes or any object you can adjust dims ad slap it on the side you like. lots of work as you are installing each one but for small areas you want exact it is a great way to get what you want. Link to comment Share on other sites More sharing options...
