KarenM Posted February 18, 2024 Share Posted February 18, 2024 Does anyone know if it's possible to create a corner window in Home Designer Suite 2022? I found instructions for Chief Architect and something that says it's for Home Designer, but I cannot get rid of the corner post. The Window Specification does not have a separate Frame choice. I've unchecked "has frame" in the casing section, but that's not doing it. What I did: 1. Placed both windows, and resized them 2. Push both windows into the corner 3. Selected both windows and opened the Window Specification dialog box. 4. Chose fixed glass, 1 lite. 5. Unchecked "has frame" in casing options. 6. Click OK. Even though I unchecked "has frame" it's still showing a frame. I have attached a screenshot of the camera view. I would appreciate any help I can get! Thank you! Link to comment Share on other sites More sharing options...
Robborito Posted February 20, 2024 Share Posted February 20, 2024 On 2/19/2024 at 2:47 AM, KarenM said: if it's possible to create a corner window Are you talking about butt glazed corner in fixed lite windows? Jeff. Link to comment Share on other sites More sharing options...
KarenM Posted February 21, 2024 Author Share Posted February 21, 2024 I'm not sure I know what that means. I'm trying to duplicate what's in the house I'm going to be renovating. It has a corner window - it's really just 2 pieces of fixed glass with a bead of silicone at the corner joint. The window was put in in 1987 and I'm not planning to replace it since it's still doing it's job just fine. Link to comment Share on other sites More sharing options...
Robborito Posted February 23, 2024 Share Posted February 23, 2024 On 2/22/2024 at 9:13 AM, KarenM said: it's really just 2 pieces of fixed glass with a bead of silicone at the corner joint In HDPro 2024 - this is what I have for butt glazing; You have to slide them into the corner to make the butt glass to happen; Jeff. Link to comment Share on other sites More sharing options...
KarenM Posted February 23, 2024 Author Share Posted February 23, 2024 Thanks. I don't think it's possible with Suite, which is what I have. Link to comment Share on other sites More sharing options...
Jo_Ann Posted February 23, 2024 Share Posted February 23, 2024 If you are desperate, you can custom build it, using a half wall, and soffits. Link to comment Share on other sites More sharing options...
