122lake Posted January 20, 2024 Share Posted January 20, 2024 I wish to use alternating offset 2x6 studs spaced 12" apart (24" centers) in a 7 1/2" wall (2x8 plates). To create a continuous thermal bridge when the walls are spray foamed. Is there a way to automatically set this up or do I need to place each stud manually? Link to comment Share on other sites More sharing options...
DavidJPotter Posted January 20, 2024 Share Posted January 20, 2024 Can you upload a sketch of what you wish to do? I need to have a more detailed understanding of your intentions to advise you with certainty. DJP Link to comment Share on other sites More sharing options...
Rookie65 Posted January 20, 2024 Share Posted January 20, 2024 It's also good for sound reduction if you do it as 2 separate walls with a space between them. Keep in mind that 2x8's are 7-1/4" Link to comment Share on other sites More sharing options...
Otrengin Posted February 23, 2024 Share Posted February 23, 2024 I have the same question. I'm looking at wall designs that have two layers of 2x4 (3.5"x1.5") fir studs with mineral wool insulation batts between the studs. I want the studs to be 16" on center, but each layer offset by half. The distance between alternating studs would be 8" apart. I've uploaded a sketch illustrating my concept. I can make HD Pro use all the layers I want. I can get the studs 16" or 8" or 24" apart, but I can't stagger the two layers of studs. If I set them each to 16" spacing, they will appear to be aligned as if they were 1.5"x7" continuous. Like the original poster, I'm trying to avoid any thermal bridging. Thank you for any suggestions you may have. Link to comment Share on other sites More sharing options...
y-g-m-n Posted February 23, 2024 Share Posted February 23, 2024 have you looked at the option page for the wall specification? STRUCTURE TAB FRAMING SECTION - At bottom Then hit HELP and it will explain it all. See screen shot. Link to comment Share on other sites More sharing options...
Otrengin Posted February 23, 2024 Share Posted February 23, 2024 Many thanks! That solved it. Ironically, I had come across that setting after I'd more or else given up. I had just set one layer to 24" spacing and the other to 16" spacing just to get some sense of the desired stagger. When I saw that setting hiding away on the Structure tab (instead of inside the Wall Types design panel itself where it arguably ought to be), I didn't see the expected result. Following your advice, I reset both layers to 16" spacing, checked the "Stagger Multiple Framing Layers", and got the desired result. I appreciate the very rapid response and good solution. Nicely done. Link to comment Share on other sites More sharing options...
