lxy1819 Posted December 15, 2023 Share Posted December 15, 2023 Hi guys. I am using Home Designer Pro 2024. I am trying to model the house in the picture. However, I do not know how to make the circled plantform beside the stairs. Anyone has clue about that ? Link to comment Share on other sites More sharing options...
DavidJPotter Posted December 15, 2023 Share Posted December 15, 2023 DJP Link to comment Share on other sites More sharing options...
Rookie65 Posted December 16, 2023 Share Posted December 16, 2023 David, the question has nothing to do with flared treads or starting steps. It has to do with the wall behind the stairs. Without seeing the floor plan and how much room is there, I am guessing that possibly a curved railing, made solid as a panel and the baluster height set to where the wall is supposed to hit might work for you? Link to comment Share on other sites More sharing options...
Solution Jo_Ann Posted December 17, 2023 Solution Share Posted December 17, 2023 When you have the stairs correct (no rail on the right side, closed stringer) then place it where it belongs. The easiest way to add the curved shelf, is with a slab. Size it the correct height and thickness to rise above the stair stringer, then arc it's shape around the stairs. Finish it off with a custom countertop , curved around the slab, for the surface. Curved slabs and curved countertops aren't as finicky as curved walls. 1 Link to comment Share on other sites More sharing options...
