How to drop in a sink for custom countertop
photogcyn
I'm using a Kohler vanity with this program's custom countertop and I can't get a HD sink to drop in.
Is there some special technique I should use? I've tried dropping it in with and without the countertop in place.
Thank you.
Sinks need a base cabinet to insert into.
Place a base cabinet, set the height to 0" and remove the Toe Kick.
Add your sink and custom countertop.
The sink will auto center over the cabinet. To move it, select the cabinet, Tab to select the sink.
