photogcyn Posted July 21, 2023 Share Posted July 21, 2023 I'm using a Kohler vanity with this program's custom countertop and I can't get a HD sink to drop in. Is there some special technique I should use? I've tried dropping it in with and without the countertop in place. Thank you. Link to comment Share on other sites More sharing options...
Jo_Ann Posted July 21, 2023 Share Posted July 21, 2023 Because you aren't using core library items, you might need to shape the counter around the sink. 1 Link to comment Share on other sites More sharing options...
solver Posted July 21, 2023 Share Posted July 21, 2023 Sinks need a base cabinet to insert into. Place a base cabinet, set the height to 0" and remove the Toe Kick. Add your sink and custom countertop. The sink will auto center over the cabinet. To move it, select the cabinet, Tab to select the sink. 1 Link to comment Share on other sites More sharing options...
