"Flip Out Window"
ChiefZachary
Fixed window on the top, doorway underneath.  Doorway reduced height, bottom raised, no threshold.
For the opened window, use a wall cabinet with a top hinge framed panel door (option set to open), (set to how many degrees open)  panel material (glass).   Set the cabinet materials to misc-no material (except for the door ).
CTRL slide the cabinet into doorway, and set the height from floor until it is correct.
Create a custom countertop extended to the outside.
