Truss top cord - built up where extended
wrcolclough
Go to solution Solved by solver,
Home Designer Pro 2022
I have a house plan with a flat roof truss (1/4"/ft actually).
In one section the upper floor is set back, but the trusses extend out the full amount like the others. like the top truss in the image.
A normal truss in this situation would have a shallower section of truss, rather than just the top cord, projecting out as in the lower truss in the image.
Is there a way for HDPro to do this automatically.
If not has anyone come up with a work around?
Thanks in advance, Bob
Well gentlemen....that was just too simple and logical for me to have guessed!  Thank you.
My next question is: now that I have the extensions in place how do I get the soffit down to the underside of them?  (and hopefully siding along the front and down the side)
I have experimented a bit and don't see how.
Thanks, Bob
Why are you modeling trusses? They will need to be designed by a truss manufacturer and you will include their data sheets in your plan.
Sub Fascia controls the position of the soffit.
Trusses build between roof and ceiling planes. Place a ceiling plane (shown in green) where you want the bottom of the truss and the truss will fill in.
Agree Eric, the truss company will do the actual design, but in the meantime i want the image to be as accurate as possible - in this case showing the thickness of the truss over the deck and the dropped ceiling/soffit that will result.  Thanks for the advice, I will add a ceiling plane.
Much appreciated, Bob
