wrcolclough Posted July 14, 2022 Share Posted July 14, 2022 Has always worked before but now I go to "Print", the print window opens up, the sheet is visible but blank. Any suggestions? Cheers, Bob Link to comment Share on other sites More sharing options...
DavidJPotter Posted July 14, 2022 Share Posted July 14, 2022 If rebooting the software does not bring back proper functioning, then I suggest you call Tech Support or post a ticket to see if they can help. In over 25 years of my use of this software I have never had this as a problem, sorry. DJP Link to comment Share on other sites More sharing options...
solver Posted July 14, 2022 Share Posted July 14, 2022 Does this happen with all plans, or at least other plans? Link to comment Share on other sites More sharing options...
wrcolclough Posted July 15, 2022 Author Share Posted July 15, 2022 Good question, I went to a previous project and yes it works fine there. Link to comment Share on other sites More sharing options...
Solution wrcolclough Posted July 15, 2022 Author Solution Share Posted July 15, 2022 Called tech support - problem solved! Somehow I had ended up with some really weird set up specs, once they were reset to normal the image appeared. Thanks David and Eric, always much appreciated. Cheers, Bob 1 Link to comment Share on other sites More sharing options...
