Tyler2022 Posted February 9, 2022 Share Posted February 9, 2022 I know that Eric has posted a example of this to a very similar question but he never showed how to get i don't know the correct terminology but the strips within the studs . I have looked in my specifications window and i just get studs and i don't want studs of insulation and I'm just curious if insulation would show in 3d Link to comment Share on other sites More sharing options...
Rookie65 Posted February 9, 2022 Share Posted February 9, 2022 I don't know if Architectural has this, yet if you go to the wall type that you want to show insulation for in 3D, change the "Main Layer" material to "Insulation w/ Studs" (found in the library under "Insulation". That will show pink fiberglass batts between the studs. The issue with doing that is if you need to draw a wall section through that wall, the studs won't show. So depending on what type of drawing you're doing, you may want to change that wall type to the insulation for 3D views, and back to framing for section views. I hope that helps? 1 Link to comment Share on other sites More sharing options...
Tyler2022 Posted February 10, 2022 Author Share Posted February 10, 2022 here's the link it's a little down of the thread Link to comment Share on other sites More sharing options...
solver Posted February 10, 2022 Share Posted February 10, 2022 On 2/9/2022 at 10:58 PM, Tyler2022 said: but he never showed how Expand Did you read to the end of that thread? Link to comment Share on other sites More sharing options...
Tyler2022 Posted February 10, 2022 Author Share Posted February 10, 2022 On 2/10/2022 at 10:28 PM, solver said: Did you read to the end of that thread? Expand yes Link to comment Share on other sites More sharing options...
Tyler2022 Posted February 13, 2022 Author Share Posted February 13, 2022 i might have screw my post up so sorry but why I'm not getting a solid between the stud bays Link to comment Share on other sites More sharing options...
Tyler2022 Posted February 14, 2022 Author Share Posted February 14, 2022 i'm just getting pink studs and I switch to the Institution with studs to see if it's going to fill in the Bay of the studs . I'm just curious if it was a option to show something between the studs and if there is a way can you show me step by step? please thank you Link to comment Share on other sites More sharing options...
solver Posted February 14, 2022 Share Posted February 14, 2022 Why are you intent on showing insulation between the studs? No one, not permitting officials, not an insulation contractor, not a builder needs this. If you feel a need to show an example, create a wall detail showing several feet of wall. Link to comment Share on other sites More sharing options...
Tyler2022 Posted February 17, 2022 Author Share Posted February 17, 2022 I'm just curious if the program does it i understand that I'm just curious Link to comment Share on other sites More sharing options...
