BartS66 Posted January 23, 2022 Share Posted January 23, 2022 I have created a second floor wall abutting a first floor roof, but am unable to close the gap where they meet. Have looked everywhere, tried everything I can think of but no luck. Is someone able to walk me through what I need to do? Thanks, Bart Home Designer Pro 2019 Link to comment Share on other sites More sharing options...
DavidJPotter Posted January 23, 2022 Share Posted January 23, 2022 Walls are portrayed by "Wall Poylines" in terms of 3D views. Those Wall Polylines are directly editable in an elevation camera and can be custom shaped to close unwanted holes such as yours bu left-click-dragging the wall to cover the hole, you may also need to adjust the roof plane edges that may be cutting that wall segment off, hard to say exactly without your plan file to inspect. DJP Link to comment Share on other sites More sharing options...
BartS66 Posted January 23, 2022 Author Share Posted January 23, 2022 Thanks DJP. I can move the corner of the wall up and down, but not side to side. (My file is 35MB so I can't attach it.) Link to comment Share on other sites More sharing options...
Solution solver Posted January 23, 2022 Solution Share Posted January 23, 2022 It's helpful to have the plan file to work with. Often difficult to understand a problem looking at an image. Close Pro before you attach, and there is a 14MB size limit. Here is a similar structure and a setting you might experiment with. And the wall on the inside. Link to comment Share on other sites More sharing options...
solver Posted January 23, 2022 Share Posted January 23, 2022 3 minutes ago, BartS66 said: My file is 35MB so I can't attach it. Make it smaller. Zip it, and or delete things unrelated to the structure. Link to comment Share on other sites More sharing options...
BartS66 Posted January 23, 2022 Author Share Posted January 23, 2022 I always forget about the mighty zip! Here's the file SOH 2021 Renovation - FINAL.zip Link to comment Share on other sites More sharing options...
BartS66 Posted January 23, 2022 Author Share Posted January 23, 2022 Eric, that did the trick, thanks! Link to comment Share on other sites More sharing options...
