Fredo649 Posted January 7, 2022 Share Posted January 7, 2022 Hello All . I am looking for a catalogue download to add into the library for "Simpson Strong Tie" or similar Does Home Designer have such an item ? This would be for Joist Hangers , Concrete base Brackets etc. Thanks Link to comment Share on other sites More sharing options...
Solution Rookie65 Posted January 7, 2022 Solution Share Posted January 7, 2022 Not available for Home Designer, yet is available in Chief.as a download Link to comment Share on other sites More sharing options...
Fredo649 Posted January 7, 2022 Author Share Posted January 7, 2022 Thankyou Link to comment Share on other sites More sharing options...
DavidJPotter Posted January 7, 2022 Share Posted January 7, 2022 I exported this from X11 which should work with your 2020 but you will need to try to import it to be sure. Link to download the Simpson Strong Tie Library file (106 Mb) DJP Link to comment Share on other sites More sharing options...
Fredo649 Posted January 7, 2022 Author Share Posted January 7, 2022 It worked David , Thank you very much. Link to comment Share on other sites More sharing options...
Rookie65 Posted January 7, 2022 Share Posted January 7, 2022 I downloaded it for Pro 22 and got "images not available", which is too bad, because it would be a helpful catalog to have. Thank you, David, for the help. Link to comment Share on other sites More sharing options...
Fredo649 Posted January 7, 2022 Author Share Posted January 7, 2022 4 minutes ago, Rookie65 said: I downloaded it for Pro 22 and got "images not available", which is too bad, because it would be a helpful catalog to have. Thank you, David, for the help. I got the same thing after trying it use it but it will still be very helpful. Link to comment Share on other sites More sharing options...
Rookie65 Posted January 7, 2022 Share Posted January 7, 2022 I just go to the Simpson catalog, as hangers usually just need to be noted and not shown Link to comment Share on other sites More sharing options...
ntraider Posted February 4, 2023 Share Posted February 4, 2023 On 1/7/2022 at 9:03 AM, DavidJPotter said: I exported this from X11 which should work with your 2020 but you will need to try to import it to be sure. Link to download the Simpson Strong Tie Library file (106 Mb) DJP Hi David - do you have an updated link for this? I'd like to download it, but the link above says it has expired. Thanks. Link to comment Share on other sites More sharing options...
ntraider Posted February 4, 2023 Share Posted February 4, 2023 @solver Thanks. 3D Warehouse has a nice selection of these. Link to comment Share on other sites More sharing options...
