EStier Posted September 17, 2021 Share Posted September 17, 2021 I am trying to do an addition to a house with a mansard roof. I don't know all of the numbers, but I should be able to get close. The plan looks good in plan view, but the elevation is all screwed up. Here is what I am trying to match Overhang is 48" Truss height is 57" from the top to bottom chord I do not know the pitch, but from the photo attached the top is about 12" in from the face of the building. The T-111 has a 12" pattern and you can see it below. The plate height of the interior walls is 96" I don't know why the elevations look the way that they do. I attached the plan and a photo of the house. I am using Home Designer Pro 2021 Tucker 2.0.plan Link to comment Share on other sites More sharing options...
solver Posted September 17, 2021 Share Posted September 17, 2021 It's helpful to have an image (screen capture) or two showing the issue as often it will be enough to provide a suggestion, and eliminate the need to download and review a plan. Link to comment Share on other sites More sharing options...
EStier Posted September 17, 2021 Author Share Posted September 17, 2021 here is a screen shot of the plan, elevation and the wall specification screen Link to comment Share on other sites More sharing options...
solver Posted September 17, 2021 Share Posted September 17, 2021 26 minutes ago, EStier said: I don't know why the elevations look the way that they do. What's wrong with the elevations? Is it the roof is covering the walls? Probably need to raise the roof. Link to comment Share on other sites More sharing options...
EStier Posted September 18, 2021 Author Share Posted September 18, 2021 I did 60" and the soffit covered the windows. I changed to 72" and the plate height looks good but I have no idea why. Here is what I get when I make that change. Not quite the same as you. Changing the pitch has no effect. Any ideas on what is happening? Link to comment Share on other sites More sharing options...
solver Posted September 18, 2021 Share Posted September 18, 2021 Link to comment Share on other sites More sharing options...
EStier Posted September 20, 2021 Author Share Posted September 20, 2021 Thanks for all of that. I still do not know why my roof is way too high. I will keep on tweaking until if figure it out. I appreciate the other tips too. Thanks Link to comment Share on other sites More sharing options...
solver Posted September 20, 2021 Share Posted September 20, 2021 6 minutes ago, EStier said: I still do not know why my roof is way too high Only one thing it could be -- the pitch is too steep. Link to comment Share on other sites More sharing options...
Jo_Ann Posted September 21, 2021 Share Posted September 21, 2021 Setting the main roof pitch to 16" looks more like the picture. Link to comment Share on other sites More sharing options...
