AngieRobshaw Posted July 28, 2021 Share Posted July 28, 2021 (edited) I'm not finding a way to create a metal ledge on a monolithic slab? Is there a way I've missed? Or must this be done manually? I have read and watched all sorts of things. My foundation does not seem to move when I change the wall specifications. The foundation remains built under the framing rather than extending out. I'm confused because under wall definitions it shows something different. Thank you, Angie Brittany & Brayden Lack Final.plan.zip Edited July 28, 2021 by AngieRobshaw fixed link Link to comment Share on other sites More sharing options...
solver Posted July 28, 2021 Share Posted July 28, 2021 Do you have Auto Rebuild Foundation checked? Link to comment Share on other sites More sharing options...
AngieRobshaw Posted July 28, 2021 Author Share Posted July 28, 2021 Yes, It is on. I have tried turning it off and on. Deleting the slab and having it rebuild. Changing the wall specs. The foundation continues to build the same. The exterior looks like this, in spite of what the wall details show. Thank you, Angie Robshaw Link to comment Share on other sites More sharing options...
solver Posted July 28, 2021 Share Posted July 28, 2021 Something wrong with your plan attachment. Try again. Link to comment Share on other sites More sharing options...
AngieRobshaw Posted July 28, 2021 Author Share Posted July 28, 2021 1 hour ago, solver said: Something wrong with your plan attachment. Try again. Ok, I rezipped it and reattached it. Link to comment Share on other sites More sharing options...
DavidJPotter Posted July 28, 2021 Share Posted July 28, 2021 Angie, I downloaded your file, turned on "Auto Rebuild Foundation" and like you, it did not work in Pro. In Chief Premier it does work like Eric said but you also have brick ledge settings in the Wall Specification dialog that you do not nave in Pro. So My advice is to just turn on the "Reference Display" while on the foundation level, turn OFF "Auto Rebuild Foundation" and then manually align your foundation wall's outer surface with the first floor walls. DJP Link to comment Share on other sites More sharing options...
solver Posted July 29, 2021 Share Posted July 29, 2021 22 hours ago, AngieRobshaw said: I'm not finding a way to create a metal ledge on a monolithic slab What is a "metal ledge"? Link to comment Share on other sites More sharing options...
AngieRobshaw Posted July 29, 2021 Author Share Posted July 29, 2021 2 minutes ago, solver said: What is a "metal ledge"? A ledge for metal siding. Link to comment Share on other sites More sharing options...
solver Posted July 29, 2021 Share Posted July 29, 2021 Like a brick ledge? Link to comment Share on other sites More sharing options...
AngieRobshaw Posted July 29, 2021 Author Share Posted July 29, 2021 2 hours ago, solver said: Like a brick ledge? Yes, just like a brick ledge, but for metal siding. Slightly different dimensions. Link to comment Share on other sites More sharing options...
solver Posted July 29, 2021 Share Posted July 29, 2021 Search for ledge in Help. You only have control over the depth, not the height. Your exterior walls are marked as Foundation Wall -- why? Link to comment Share on other sites More sharing options...
AngieRobshaw Posted July 29, 2021 Author Share Posted July 29, 2021 13 hours ago, solver said: Search for ledge in Help. You only have control over the depth, not the height. Your exterior walls are marked as Foundation Wall -- why? Making it a foundation wall was one of the many things I tried, to see what might cause the foundation to move. I will check out "ledge". Link to comment Share on other sites More sharing options...
