Backsplash wrapping around a window
briancaos
I have created a kitchen with a backsplash. The backsplash wraps perfectly around the windows, as you can see in the attachment "backsplash OK".
I then reversed the plan. After then, the backsplash will not wrap around the windows in the reversed plan, see attachment "backsplash reversed error".
I have tried just about everything; removed and re-added the window, removed and re-added the backsplash, the cabinets, changed material, thickness, ... but nothing will make the backsplash wrap around the windows.
What can I do?
- Best regards
Brian Pedersen
Denmark
Not a pro, just a home enthusiast.
Parcel Home 153sqm - Reversed2.plan
Thanks for the help. I can see that my version (Home Designer Architectural 2014) does not have the backsplash tool. I guess it's time to save up for an upgrade.
Again thank you for taking the time to look at my designs.
Regards,
Brian Pedersen
Denmark
Just a home enthusiast
