chrisnoland Posted February 6, 2015 Share Posted February 6, 2015 All, applogize for the noob question but trying to understand how to lay out a cabana where the are no walls but 4 (or more) posts on the corners but then a full roof. I have been through most of the online videos and have not see a way to build it as a stand alone structure Any pointers would be great Thanks Chris Link to comment Share on other sites More sharing options...
DavidJPotter Posted February 6, 2015 Share Posted February 6, 2015 Draw using "Railing Walls" set to "Post to Beam". You can then turn on of off the railings depending upon your purpose and look. Try it and see for yourself. DJP Link to comment Share on other sites More sharing options...
chrisnoland Posted February 26, 2015 Author Share Posted February 26, 2015 David thanks for the tip, that worked.... but now how do I change the size of the post to something like 12"x12" Chris Link to comment Share on other sites More sharing options...
solver Posted February 26, 2015 Share Posted February 26, 2015 Draw 4 walls. Set them to invisible. You may then add columns as you like. 1 Link to comment Share on other sites More sharing options...
chrisnoland Posted February 26, 2015 Author Share Posted February 26, 2015 Eric, That is great.... exactly what I wanted to do with the stone around the bottom.... now to figure out how to do that all :-) Thanks for the suggestion Chris Link to comment Share on other sites More sharing options...
solver Posted February 26, 2015 Share Posted February 26, 2015 Those columns are from the library, but it's easy to make your own using the slab tool, soffits etc. I believe there is a bonus library that has columns as well. Link to comment Share on other sites More sharing options...
