Colemr Posted February 26, 2021 Share Posted February 26, 2021 Hello. I spent hours trying to solve an issue, and was helping someone might offer me some advice. When a wall is part interior (below the roof line) and part exterior (above the roof line), I cannot get it to properly show interior section. Render shows exterior surface. I created the attached simple plan as an example. The right side of the door shows the problem -- the exterior siding shows as the interior surface. Over the door and on the left side of the door, I placed a thin wall to "hide" the siding. This is the only thing I could find to at least cover the problem -- not really fix it. Is there a better solution with Architectural 2021? I would greatly appreciate help in solving this issue. Thanks! Simple Test.plan Link to comment Share on other sites More sharing options...
solver Posted February 26, 2021 Share Posted February 26, 2021 Thanks for the signature and test plan. With Architectural, your best option is a Custom Backsplash. Make it 1/2" (or whatever thickness you are using) drywall, set to Cut Finish Layers. Draw it to cover the exposed siding. It will automatically cut around the door. Link to comment Share on other sites More sharing options...
solver Posted February 26, 2021 Share Posted February 26, 2021 Not that it matters, but Pro has a setting that lets you specify 2 wall types in a single wall, and specify that the lower wall type is to be used where a roof butts a wall. Link to comment Share on other sites More sharing options...
Colemr Posted February 26, 2021 Author Share Posted February 26, 2021 Thank you for your quick reply. I wish I had asked before spending 20+ hours trying to solve. Every other issue I had I was ultimately able to solve by investigation until I learned what I was doing wrong. I assumed the same was true with this issue. One last question .... can I fix this with Pro? Thanks again! Link to comment Share on other sites More sharing options...
Colemr Posted February 26, 2021 Author Share Posted February 26, 2021 Sorry .... didn't see your second post ... thanks! Link to comment Share on other sites More sharing options...
DavidJPotter Posted February 26, 2021 Share Posted February 26, 2021 Architectural 2021 also has a "Wall Covering Tab in the Wall Specification Dialog. It also has a "Pony Wall" tool that can be customized in Default Settings - Wall and the option mentioned by Eric about the Custom Backsplash tool. All function perfectly once learned. DJP Link to comment Share on other sites More sharing options...
