LeekyBoatStudio Posted February 25, 2021 Share Posted February 25, 2021 Hi there! I love this software. I was wondering if there is a way to create a new default set that you can choose on startup? We have the list with default, American Casual, etc and I am wondering if I set up new defaults on a plan I am building if I can save those setting to be added to that initial list so I can then use those defaults in a new plan without having to set them all up again. I have Home Design Architectural 2021. Thank you! Leek Link to comment Share on other sites More sharing options...
solver Posted February 25, 2021 Share Posted February 25, 2021 On 2/25/2021 at 12:28 PM, LeekyBoatStudio said: to create a new default set Search my YouTube channel (link in my signature) for template. Added 4/24/2023 This is in reply to the comment by Rookie65 below. If you follow the instructions in my video, you will create an actual Template plan that works like any of the ones supplied by Home Designer. There is no need to Save As. 1 Link to comment Share on other sites More sharing options...
LeekyBoatStudio Posted February 25, 2021 Author Share Posted February 25, 2021 Thank you Eric! One small follow up question. Once you make the template and open it up if you change defaults on that plan will it update the template too or will you need to resave the template? Also, I subscribed to your channel. Link to comment Share on other sites More sharing options...
Rookie65 Posted February 25, 2021 Share Posted February 25, 2021 What you do is create the new template. Then when you start a new plan using that template, hit "save as" first and then rename it. That way your master stays the same and you can change your defaults for the new plan without it changing anything in your master. 1 Link to comment Share on other sites More sharing options...
LeekyBoatStudio Posted February 25, 2021 Author Share Posted February 25, 2021 Thank you Keith! That answers my question. Link to comment Share on other sites More sharing options...
Rookie65 Posted February 25, 2021 Share Posted February 25, 2021 Depending on what type of work you do, you may want to look at upgrading to Pro before you get too many master created. If you design with complicated roofs, want the ability to change floor framing materials defaults, use arched windows, etc., you'll find it's worth it in the long run with the added flexibility of design. 1 Link to comment Share on other sites More sharing options...
solver Posted February 25, 2021 Share Posted February 25, 2021 38 minutes ago, LeekyBoatStudio said: I subscribed to your channel. Thanks. Keep in mind that most content is for Chief, some of it works for Pro, and a subset of that works for Architectural and Suite. 1 Link to comment Share on other sites More sharing options...
