AngieRobshaw Posted January 8, 2021 Share Posted January 8, 2021 I was able to import a survey dxf file plan but the measurements the program read, it interpreted in Inches. I have tried to change it to feet, section by section, but it causes chaos. Is there another way that I can change the way the program reads the measurements? I need the plot to be to scale so I can add in the buildings. Thank you, Angie Robshaw CR 401.plan Link to comment Share on other sites More sharing options...
Robborito Posted January 9, 2021 Share Posted January 9, 2021 Maybe the DXF needs to changed? Link to comment Share on other sites More sharing options...
solver Posted January 9, 2021 Share Posted January 9, 2021 You can always enter the info manually. If you want help, someone will probably need the dxf. Link to comment Share on other sites More sharing options...
