socmat23 Posted December 31, 2020 Share Posted December 31, 2020 How would I go about making this roofline? I have tried it with setting the ceiling heights to 0", but the issue I am having is the returns only go as far as the exterior wall returns, and I end up with no exterior wall at the upper gable. Also, when I try to make the dormers it will not let me put them on the edge of the house. The other issue I was having is that the upper shed dormer is outside the footprint of the front door below. I would appreciate any help someone can give. Thanks Link to comment Share on other sites More sharing options...
socmat23 Posted December 31, 2020 Author Share Posted December 31, 2020 Here is the file Home Designer Pro 2021 (64 bit).lnk Link to comment Share on other sites More sharing options...
solver Posted December 31, 2020 Share Posted December 31, 2020 The not very helpful answer is to learn to use the roof tools. Not difficult, but will take study and practice. I don't see any dormers, so maybe start by rethinking your approach to the roof. Look at it like it's a first floor that just happens to be sitting on top of another structure. And your file did not correctly attach. Close Pro, then attach it just like you did the image. 1 Link to comment Share on other sites More sharing options...
socmat23 Posted December 31, 2020 Author Share Posted December 31, 2020 That should work better for a file. I guess if I don't look at the bump-outs as dormers I'm not sure how I would look at them? Future House.plan Link to comment Share on other sites More sharing options...
solver Posted December 31, 2020 Share Posted December 31, 2020 25 minutes ago, socmat23 said: I don't look at the bump-outs as dormers I'm not sure how I would look at them? 2 hours ago, solver said: Look at it like it's a first floor that just happens to be sitting on top of another structure. Take away the 1st floor. How would you model a house that looks like your 2nd floor? Link to comment Share on other sites More sharing options...
socmat23 Posted December 31, 2020 Author Share Posted December 31, 2020 Looking at it that way I guess I would build the center section (in-between each larger gable) with exterior walls, ignoring the farthest ends, ad in-wall breaks towards the end to prevent the valleys from coming all the way to the corners of the bump-outs, and then try and do a shed roof on the section in the middle? Link to comment Share on other sites More sharing options...
Jo_Ann Posted December 31, 2020 Share Posted December 31, 2020 You are already off to a bad start. You did not partition off the garage from the house, therefore the main house 1st floor is set at-12" instead of 0". Link to comment Share on other sites More sharing options...
socmat23 Posted December 31, 2020 Author Share Posted December 31, 2020 Jo_Ann, That happened when I deleted all of the interior walls I had already created to put the simplest file on this forum to address the roof issue, and I'm guessing it has no bearing on how to break the roof up as shown in the picture. so if you have any input on that, that would be great. Thanks Link to comment Share on other sites More sharing options...
solver Posted December 31, 2020 Share Posted December 31, 2020 Link to comment Share on other sites More sharing options...
socmat23 Posted January 1, 2021 Author Share Posted January 1, 2021 Getting closer, but not sure if did it the right way. still need to install attic walls? Future House.plan Link to comment Share on other sites More sharing options...
