solver Posted December 31, 2020 Share Posted December 31, 2020 23 minutes ago, sfo1ckh said: I tried wall and it would not work What didn't work? What did you do? 24 minutes ago, sfo1ckh said: I did what you said and used sofits I never said to use soffits alone, just suggested you could use soffits along with walls and doors. Link to comment Share on other sites More sharing options...
solver Posted December 31, 2020 Share Posted December 31, 2020 6 hours ago, sfo1ckh said: I have tried to find different arched mouldings An arch top doorway has a casing (trim) that you may assign a molding to. There are no arched moldings to find. Link to comment Share on other sites More sharing options...
sfo1ckh Posted December 31, 2020 Author Share Posted December 31, 2020 When I tried to use a wall, I could not get it work as far as the top of the wall would go up to the sky; tried half wall, no good....sofits worked for what I wanted up until now Link to comment Share on other sites More sharing options...
sfo1ckh Posted December 31, 2020 Author Share Posted December 31, 2020 You lead me to believe that I would have to upgrade to get this done, now you are saying to just use walls? I get that you want me to learn, but you could have just said that; because now with what I have already done, I am not going to delete all of the detail work that I did and rebuild the entire front with walls and doorways, I will just live with what I have. Link to comment Share on other sites More sharing options...
solver Posted December 31, 2020 Share Posted December 31, 2020 On 12/19/2020 at 7:45 PM, solver said: You must do this with walls and use a doorway or window etc to create the arch. You don't need to use only walls. You can use soffits too. Walls and soffits can share the same space, or soffits can be positioned on the wall to give you something to place a molding on. Try to think of the tools you have available and what they are capable of, then use them as needed to build the model. With Suite, you have limited options, so you need to make up for the shortcomings of the software. I don't know how I could have been clearer. I never said you should upgrade or indicated you could not do what you wanted with Suite, although because I don't have the plans, I could not be sure. Link to comment Share on other sites More sharing options...
Jo_Ann Posted December 31, 2020 Share Posted December 31, 2020 I don't believe you got the arch from a soffit. How did you do it? Do you not know that you can draw walls through soffits, without deleting the soffits? Link to comment Share on other sites More sharing options...
sfo1ckh Posted January 2, 2021 Author Share Posted January 2, 2021 I used an arch doorway (Tambour Arch); but that does not have the molding option that I need to give the look of the original house? I tried a wall with an arch doorway; but again that does not have any molding options; so I still do not understand what you or Solver is stating; I am sure that you are able to get the look since you did it, just everything you have me try does not work for me.. I would attached is my backup file; but this blog only allows 25 K and my file is over 100. Link to comment Share on other sites More sharing options...
sfo1ckh Posted January 2, 2021 Author Share Posted January 2, 2021 Also forgot to mention that using a wall does not work as I said before it goes all the way up to the roof and I have irregular openings between pillars that would make those cutouts impossible? Link to comment Share on other sites More sharing options...
sfo1ckh Posted January 2, 2021 Author Share Posted January 2, 2021 Well, thank you for your final findings of that I cannot do this in Architectural 2021, thought I was just plain stupid or ?? and glad I did not try to redo the entire front facade, as that took a lot of work to get to this stage. I am okay with what I have, it's good enough, but if there was a way, I would do it as I am now doing the fine detail work as I see it. I really appreciate all of the help you have given me in all of my problems; I do not plan to do this past this one project of rebuilding my fire loss home, so people like me, I think, just want a fast and simple answer. I have spent over 2,000 hours so far on Home Designer (slow learner), so it's not like I haven't done some homework, just sometimes it's "just tell me the answer". like you just did. 1_2_21 backup only.zip Link to comment Share on other sites More sharing options...
