sfo1ckh Posted December 9, 2020 Share Posted December 9, 2020 Does anyone know how to create the front columns on the attached picture using Suite? Link to comment Share on other sites More sharing options...
solver Posted December 9, 2020 Share Posted December 9, 2020 Which columns are you asking about? Link to comment Share on other sites More sharing options...
sfo1ckh Posted December 9, 2020 Author Share Posted December 9, 2020 Both the ones on the left balcony and over the front door Link to comment Share on other sites More sharing options...
solver Posted December 9, 2020 Share Posted December 9, 2020 You can make square columns from cabinets, soffits or shapes. Image is a cabinet. Similar for the arched opening. Link to comment Share on other sites More sharing options...
sfo1ckh Posted December 9, 2020 Author Share Posted December 9, 2020 How do I create the arch entry way which is not attached to the building; although the actual picture does not show this? Link to comment Share on other sites More sharing options...
sfo1ckh Posted December 9, 2020 Author Share Posted December 9, 2020 I am trying to recreate the closeup picture of the second floor balcony and front door facade and not sure where to even begin? Link to comment Share on other sites More sharing options...
sfo1ckh Posted December 10, 2020 Author Share Posted December 10, 2020 Sorry, thought I had done this back then and just last week, was in wrong area, just did now. Thanks for the tip on cabinets, sofits ... attached picture of what I did so far, can you give an idea on how I would create the arch between the columns and/or the stucco around the two windows on the right side of the front door? Link to comment Share on other sites More sharing options...
sfo1ckh Posted December 11, 2020 Author Share Posted December 11, 2020 I am not finding anything on creating an arch in the middle of the to square columns in anything I have tried? Is there anything possible? Link to comment Share on other sites More sharing options...
solver Posted December 11, 2020 Share Posted December 11, 2020 On 12/11/2020 at 12:29 AM, sfo1ckh said: Is there anything possible Expand What tool do you have available that would create an arched opening? Hint -- they are all over the house. Link to comment Share on other sites More sharing options...
sfo1ckh Posted December 11, 2020 Author Share Posted December 11, 2020 I tried doors and archways, would not take, I assume that doors and doorways do not take unless it's attached to a wall and those are sofits? Link to comment Share on other sites More sharing options...
sfo1ckh Posted December 11, 2020 Author Share Posted December 11, 2020 Windows does the same thing Link to comment Share on other sites More sharing options...
sfo1ckh Posted December 19, 2020 Author Share Posted December 19, 2020 Anybody have any suggestions on making the arched entry way that was built with sofits? Link to comment Share on other sites More sharing options...
Jo_Ann Posted December 20, 2020 Share Posted December 20, 2020 Eric gave you the answer, and you followed that up by answering your own question. Link to comment Share on other sites More sharing options...
sfo1ckh Posted December 20, 2020 Author Share Posted December 20, 2020 Eric made me think it was doors or windows, which it is not, since that was built with a sofit. Tried wall, did not work, what am I missing? Are you saying it cannot be done? Link to comment Share on other sites More sharing options...
solver Posted December 20, 2020 Share Posted December 20, 2020 You would get better help if we could see what you are trying to model. A head on picture taken from the street does not provide enough detail. You must do this with walls and use a doorway or window etc to create the arch. You don't need to use only walls. You can use soffits too. Walls and soffits can share the same space, or soffits can be positioned on the wall to give you something to place a molding on. Try to think of the tools you have available and what they are capable of, then use them as needed to build the model. With Suite, you have limited options, so you need to make up for the shortcomings of the software. Link to comment Share on other sites More sharing options...
solver Posted December 20, 2020 Share Posted December 20, 2020 You can do things like this easily with Architectural and Pro. Link to comment Share on other sites More sharing options...
sfo1ckh Posted December 20, 2020 Author Share Posted December 20, 2020 You said I have the tools in Suite, but I guess I do not? Maybe upgrade, still thinking about it....? Link to comment Share on other sites More sharing options...
sfo1ckh Posted December 21, 2020 Author Share Posted December 21, 2020 The actual house was built in Florida and I just purchased the plans from Eplans and that is the only picture that exist of the actual house. Link to comment Share on other sites More sharing options...
sfo1ckh Posted December 23, 2020 Author Share Posted December 23, 2020 To Eric and Joann, Thank you for all of your help and advice, upgraded to Archiectural 2021 and was able to get the look I wanted in minutes. Great! Link to comment Share on other sites More sharing options...
sfo1ckh Posted December 30, 2020 Author Share Posted December 30, 2020 I am now working on the trim over the front door entrance. I have tried to find different arched mouldings but could not find anything that Designer Architectural 2021 has. I appreciate any ideas to try? Link to comment Share on other sites More sharing options...
Jo_Ann Posted December 31, 2020 Share Posted December 31, 2020 You need to update your signature. Open the core library and select any one of the moldings. Click on the door casing in a 3d view. Did you delete the microwave oven that is in outer space southeast of the house? It is creating havoc with the full perspective overview. Link to comment Share on other sites More sharing options...
sfo1ckh Posted December 31, 2020 Author Share Posted December 31, 2020 I must be really dumb; but I could not find anything that would put a round arch trim like you were able to do: and yes I did delete the microwave. I went to moldings, doors and nothing would take because there is only a doorway, not a door? Where should I look? Link to comment Share on other sites More sharing options...
sfo1ckh Posted December 31, 2020 Author Share Posted December 31, 2020 Do I have to delete what I have for the archway already and build a new wall and then install the round door way? If so, I built the wall with sofits and the archway will not take in a sofit, it would require a complete rebuild of my entire entrance? Link to comment Share on other sites More sharing options...
solver Posted December 31, 2020 Share Posted December 31, 2020 On 12/20/2020 at 2:45 AM, solver said: You must do this with walls and use a doorway or window etc to create the arch. You don't need to use only walls. You can use soffits too. Walls and soffits can share the same space, or soffits can be positioned on the wall to give you something to place a molding on. Try to think of the tools you have available and what they are capable of, then use them as needed to build the model. Expand Link to comment Share on other sites More sharing options...
sfo1ckh Posted December 31, 2020 Author Share Posted December 31, 2020 As you stated above, I tried wall and it would not work, so I did what you said and used sofits, now you are telling I should have used walls? Link to comment Share on other sites More sharing options...
