DanielJay Posted November 25, 2020 Share Posted November 25, 2020 I am using 8" CMU Block for my exterior walls. The house is 1 story with different ceiling heights and therefore different roof heights from room to room. There is one section of wall that shows between a higher hip roof and a lower hip roof and it displays as block. I am trying to paint the block the same color as the rest of the exterior of the home but it doesn't seem to work. When I use the "Material Painter" tool nothing happens. I have tried using "wall coverings" but it also does not do the job. I have tried making it a pony wall, but it doesn't help. And I have tried selecting Wall Type below if separated by butting roof but it doesn't help. What am I doing wrong? Also, I have a similar "attic wall" on another portion of the house and I had no problem using the "material painter" to paint the wall to match the exterior, however this wall is not block but I don't understand why that matters. I posted pictures of both cases and the simplified plan. FA 20 Help.zip Link to comment Share on other sites More sharing options...
DavidJPotter Posted November 25, 2020 Share Posted November 25, 2020 In a camera view, select the unwanted wall, open its dialog box and then go to "Wall Types" and change just that one wall to the wall type that you do wish to be there. Then click "OK" to close the dialog box. DJP Link to comment Share on other sites More sharing options...
DanielJay Posted November 25, 2020 Author Share Posted November 25, 2020 I guess I incorrectly called it an "attic wall". The wall type seams to be correct. On the "exterior side" which is outside next to the front door it is a Block wall that goes all the way up to the 15' ceiling above. On the interior side it is block wall with 2" of furring strips and drywall until it protrudes through the ceiling of that room and then it is just block. I just can't seem to paint the block. Link to comment Share on other sites More sharing options...
solver Posted November 25, 2020 Share Posted November 25, 2020 Pro does not have the Wall Cap feature I show in the video. Try a Custom Countertop and shape it around the walls instead of using multiple pieces. You can add a molding to it if you want a profile on the edge. Watch on YouTube: http://youtu.be/otWAwX67SmM?hd=1 Link to comment Share on other sites More sharing options...
