GLOBE-Res Posted November 8, 2020 Share Posted November 8, 2020 iS IT POSSIBLE TO COLOR GUTTERS AND IF SO HOW? Link to comment Share on other sites More sharing options...
solver Posted November 8, 2020 Share Posted November 8, 2020 Are you having an issue coloring gutters? In the current versions of Pro -- don't know about 2018, you can change the materials like other objects via defaults or by painting. Link to comment Share on other sites More sharing options...
GLOBE-Res Posted November 8, 2020 Author Share Posted November 8, 2020 I found that by using the DROPPER you can suck up the color of another item and use the SPRAY CAN to PAINT the gutters. And I'm using PRO 2018 Link to comment Share on other sites More sharing options...
DavidJPotter Posted November 8, 2020 Share Posted November 8, 2020 Using the Material Eye Dropper or Material painter tools is ONE way to accomplish a material assignment. The most usual way is by way of Default Settings - Roof - Materials Tab - Gutters. The fact is that there are numerous ways to set the Gutter Material within the software and it is a good idea to find out about them all and then evaluate for yourself which one is the quickest, best way for any instance of need. DJP Link to comment Share on other sites More sharing options...
