RobinD Posted November 1, 2020 Share Posted November 1, 2020 All you experts out there please excuse my temporary loss of cognizant mind functions but for the life of me I can't figure out how to view the studs in the wall circled. The rest of the plan shows stud locations and spacing and I'll be dammed if i can remember how i was able to enable that. What am I messing? Thanks in advance. Link to comment Share on other sites More sharing options...
DavidJPotter Posted November 1, 2020 Share Posted November 1, 2020 1 hour ago, RobinD said: I can't figure out how to view the studs in the wall circled. It appears to me that they ARE showing, what am I missing, please? DJP Link to comment Share on other sites More sharing options...
RobinD Posted November 1, 2020 Author Share Posted November 1, 2020 The 2x6 wall "underneath" the garage wall (yellow) Link to comment Share on other sites More sharing options...
RobinD Posted November 1, 2020 Author Share Posted November 1, 2020 Make that just below the yellow garage wall Link to comment Share on other sites More sharing options...
DavidJPotter Posted November 1, 2020 Share Posted November 1, 2020 Without the plan to inspect the offending wall's dialog box, I would carefully inspect that wall's settings and if all else fails, you can manually frame that wall. The most likely culprit is settings usually. DJP Link to comment Share on other sites More sharing options...
RobinD Posted November 2, 2020 Author Share Posted November 2, 2020 Thought it would be something an expert would know off the top of their head. The weirdness started when I replaced a ICF wall (the Garage wall in question) with a standard 2x6 "siding -6" wall which was in place originally and showing the studs. I changed to ICF in the Wall Spec box and then later changed my mind and reverted to the stud wall. The zipped plan file is enclosed. Wall weirdness.zip Link to comment Share on other sites More sharing options...
solver Posted November 2, 2020 Share Posted November 2, 2020 Did you try just redrawing the wall? Link to comment Share on other sites More sharing options...
DavidJPotter Posted November 2, 2020 Share Posted November 2, 2020 DJP 1 Link to comment Share on other sites More sharing options...
RobinD Posted November 3, 2020 Author Share Posted November 3, 2020 Thanks for that. Unfortunately my 2020 version doesn't have the build framing for selected object command in the toolbar. I'll look around and see if I can find it. Thanks to both you and Solver. Link to comment Share on other sites More sharing options...
