LindaM Posted October 7, 2020 Share Posted October 7, 2020 I have two questions: I'm working on an 1850 farmhouse staircase railing that does a u turn at the landing at top of stairs; it u's into the 2nd floor railing. Can I draw this in HD Pro 2020? My other question is is there a way to create a round railing? This is the only picture I have of the railing from another room but you can see how it turns to continue down staircase. Thanks so much! Link to comment Share on other sites More sharing options...
DavidJPotter Posted October 7, 2020 Share Posted October 7, 2020 Unlike Chief Premier that has custom molding polylines Home Designer Pro does not. What can be done in Pro is by the additional use of a free software program called "Sketch Up". In sketch up you can make, from scratch 3D symbols and objects that can then be imported into Pro as symbols for use in your plan files. (Groan ! another software program to learn!). Sketch UP, as I said is a free cloud based software application that is easy to learn and use. You can make Newels and Balusters round or square by way of the respective dialog box for rails and stairs but rails, in Pro are by default "square", sorry. BTW I see no railings in your posted image, just plumbing and electrical conduits. DJP Link to comment Share on other sites More sharing options...
LindaM Posted October 7, 2020 Author Share Posted October 7, 2020 Thanks so much, I actually know a little bit about SU but agree, UGH. The staircase is beyond the bathroom door, you can see it, how odd? Sorry bout that........ Link to comment Share on other sites More sharing options...
solver Posted October 7, 2020 Share Posted October 7, 2020 On 10/7/2020 at 4:56 PM, LindaM said: but you can see how it turns to continue down staircase Expand Not really. Link to comment Share on other sites More sharing options...
LindaM Posted October 7, 2020 Author Share Posted October 7, 2020 Eric you're right.....this isn't the actual staircase but similar to what it does: Link to comment Share on other sites More sharing options...
solver Posted October 7, 2020 Share Posted October 7, 2020 On 10/7/2020 at 4:56 PM, LindaM said: Can I draw this in HD Pro 2020? Expand Have you tried? Link to comment Share on other sites More sharing options...
LindaM Posted October 7, 2020 Author Share Posted October 7, 2020 Within stairs, yes I don't see how to. Searched help topics and similar threads but I wasn't finding anything related to curved/u shaped railings. Link to comment Share on other sites More sharing options...
solver Posted October 7, 2020 Share Posted October 7, 2020 This is rough, and may not do everything you need, but should get you started. I placed a landing at the top of the stairs and set its height to be the same as the 2nd floor. This gives the stair railing something to connect to and create the transitions. Link to comment Share on other sites More sharing options...
LindaM Posted October 7, 2020 Author Share Posted October 7, 2020 Earlier, when I was searching for help I found a thread that lead to a You Tube video you recorded to help someone that was creating a curved staircase with multiple landings. Thanks so much for this, appreciate it! Link to comment Share on other sites More sharing options...
