SignatureDB Posted October 2, 2020 Share Posted October 2, 2020 Trying to add a deck to a (~flat) rooftop. HD wants to add posts/beams, warns that deck is built over a non-deck floor. Tried specifying as Balcony as well as deck. Can't seem to build a 'stand-alone' deck and drop iit on top of the roof. Would appreciate suggestions for an approach to this. Thanks. Plan attached. Don HD Pro 2021 Win7 workstation PCotter Garage2.plan Link to comment Share on other sites More sharing options...
solver Posted October 2, 2020 Share Posted October 2, 2020 I've not looked at the plan -- posting a 3D image is helpful as often suggestions can be made without needing to download and open a plan. If you have a structure with some sort of roof, you might try building the deck on the floor above, then lowering it. You are free to delete framing that is not needed. Link to comment Share on other sites More sharing options...
DavidJPotter Posted October 3, 2020 Share Posted October 3, 2020 Link to comment Share on other sites More sharing options...
