mikenlara Posted July 31, 2020 Share Posted July 31, 2020 using HD pro 2021 It looks like if i select a countertop material from the default or core catalogs it calculates square footage, but if i try to change that granite to one from a manufacturer (cactus stone as shown below) it will not calculate the square footage. does anyone know a way around this? any help is greatly appreciated. Link to comment Share on other sites More sharing options...
solver Posted July 31, 2020 Share Posted July 31, 2020 I believe the material needs to be set to Area -- it's now set to Count. You need to report this directly to Chief so it can be corrected. Link to comment Share on other sites More sharing options...
mikenlara Posted July 31, 2020 Author Share Posted July 31, 2020 thank you, i am still working on the signature thing. so i figured it out, you have to get the material you want and copy it into your library. then you can open it for editing and change the calculation to area. i did that and ran a new materials list and it worked. Link to comment Share on other sites More sharing options...
DavidJPotter Posted July 31, 2020 Share Posted July 31, 2020 DJP Link to comment Share on other sites More sharing options...
