313Architect Posted July 14, 2020 Share Posted July 14, 2020 Hi, over the past few days I have been playing around on how to adjust the wall and foundation height. I feel like I have a good understanding on how to edit each but I am having one issue. I want to edit ( raise the 1st floor height ) but the foundation also rises. So my question is there a way to lock the height of foundation so I can edit the 1st floor without the foundation rising ? The reason I want to do this is because I want to keep the foundation under the terrain. Also some of my notes I took are below to help anyone new out ↴ Thank you James Simmons ( To change wall height - open specification - structure - change floor “ To match terrain height - with foundation deleted -7” ) To change Foundation height ( Which changes wall height ) - open specification - structure - change ceiling height - -19” When switched to garage - open specification for the room - structure - floor - -16” - 18” is better To have floor at terrain ground level - structure - floor - -28” Link to comment Share on other sites More sharing options...
DavidJPotter Posted July 14, 2020 Share Posted July 14, 2020 As you have seen, the software is programmed to do what you have been seeing. The same is true for multiple-stacked rooms, floor to floor (if you lower the second floor floor height, it automatically lowers the ceiling below. Same thing with a first floor, whether you raise or lower the floor height, the software is programmed to respond to that change. It sounds as if you wish to create a first floor room with NO foundation. Perhaps you need to describe in greater detail, your problem? DJP Link to comment Share on other sites More sharing options...
solver Posted July 14, 2020 Share Posted July 14, 2020 20 minutes ago, 313Architect said: The reason I want to do this is because I want to keep the foundation under the terrain Change the Terrain height in relation to the structure. 1 Link to comment Share on other sites More sharing options...
313Architect Posted July 15, 2020 Author Share Posted July 15, 2020 21 hours ago, DavidJPotter said: It sounds as if you wish to create a first floor room with NO foundation. Perhaps you need to describe in greater detail, your problem? @DavidJPotter I'll try that. For my next project I just had numerous areas where some parts of the house where elevated and I wanted to see if I could lock the foundation height from coming from the terrain but its ok 21 hours ago, solver said: Change the Terrain height in relation to the structure. @solver I have done that and as I was playing around with it yesterday and I noticed in the 3D view I could pull down the front exterior material over the foundation wall - for anyone new Thank you both Link to comment Share on other sites More sharing options...
DavidJPotter Posted July 15, 2020 Share Posted July 15, 2020 7 hours ago, 313Architect said: I wanted to see if I could lock the foundation height All walls are adjustable via their "Wall Poly lines" in cross section views manually to whatever height you require. DJP Link to comment Share on other sites More sharing options...
