ChiefJeet Posted July 9, 2020 Share Posted July 9, 2020 I keep getting a situation where the cavity wall overlaps the existing wall as shown on the left side of the image. The overlap will then also be displayed on the side elevation. Strangely, it only happens on one side. I have searched on the forum for overlapping walls but could not find anything. A help on this would be appreciated. AAPractice.plan Link to comment Share on other sites More sharing options...
solver Posted July 9, 2020 Share Posted July 9, 2020 See if this helps. Link to comment Share on other sites More sharing options...
ChiefJeet Posted July 9, 2020 Author Share Posted July 9, 2020 I'm afraid, it does not help. Cannot locate "framing reference to remove" in cavity wall or the solid wall. Tried with "through wall at end and start" ticked and it only makes the overlap longer. File added for demo. Plan1L.plan Link to comment Share on other sites More sharing options...
ChiefJeet Posted July 13, 2020 Author Share Posted July 13, 2020 Still having issue with overlapping walls. Eric referred me to a link but it has not resolved the problem. Further help would be appreciated. 1 Link to comment Share on other sites More sharing options...
Rookie65 Posted July 13, 2020 Share Posted July 13, 2020 Make sure the wall framing is aligned. See if there is a difference between the wall you want on the right versus the left one. Or even try reading through your reference manual under walls. Don't type in things like "overlapping", just look for walls. Link to comment Share on other sites More sharing options...
solver Posted July 13, 2020 Share Posted July 13, 2020 I spent some time working on this problem when it was first posted and did not find a solution. Suggest sending in to support. I tried using different wall definitions, Room Divider walls etc and none of the Home Designer capable tricks worked. Chief has a tool that lets you edit these difficult wall intersections manually, but it's not available in HD. Link to comment Share on other sites More sharing options...
