etaylor0711 Posted June 15, 2020 Share Posted June 15, 2020 I am trying to print a camera view of a floor plan, for the flooring it is only displaying the 3D Backdrop. ive removed the backdrop, checked to make sure the flooring layers were displayed , toggled on and of and on again the texture, nothing seems to work. It always shows as white. I am using Home Designer Suite 2020 HDSuite2020flooring.pdf Link to comment Share on other sites More sharing options...
solver Posted June 15, 2020 Share Posted June 15, 2020 9 minutes ago, etaylor0711 said: I am trying to print a camera view of a floor plan Are you using a Doll House camera? Link to comment Share on other sites More sharing options...
etaylor0711 Posted June 15, 2020 Author Share Posted June 15, 2020 ive tried Dollhouse view as well as full camera view. Neither of them showing flooring Link to comment Share on other sites More sharing options...
etaylor0711 Posted June 15, 2020 Author Share Posted June 15, 2020 does this help? Link to comment Share on other sites More sharing options...
etaylor0711 Posted June 15, 2020 Author Share Posted June 15, 2020 i have the flooring finish selected as well. Ceiling is showing the way i want it, but not sure what i am doing wrong Link to comment Share on other sites More sharing options...
solver Posted June 15, 2020 Share Posted June 15, 2020 4 minutes ago, etaylor0711 said: does this help? Yes -- thanks. If you have a foundation/floor structure you should see something, unless these things are off in Display Options. Attach the plan file -- close Suite first, and someone will have a look. Link to comment Share on other sites More sharing options...
etaylor0711 Posted June 15, 2020 Author Share Posted June 15, 2020 Thanks! Beau_Claire_Starter_Home_Plan_auto_save.plan Link to comment Share on other sites More sharing options...
solver Posted June 15, 2020 Share Posted June 15, 2020 15 minutes ago, solver said: If you have a foundation/floor structure you should see something Build the foundation. Link to comment Share on other sites More sharing options...
etaylor0711 Posted June 15, 2020 Author Share Posted June 15, 2020 That worked! Thank you so much! Link to comment Share on other sites More sharing options...
DavidJPotter Posted June 15, 2020 Share Posted June 15, 2020 Additional data DJP Link to comment Share on other sites More sharing options...
