SomeCallMeTim Posted June 4, 2020 Share Posted June 4, 2020 can someone describe the steps required to create a parapet gable wall, either sloped or stepped, where the gable rises above the roof and the roof stops at the inside face of the gable? Link to comment Share on other sites More sharing options...
solver Posted June 4, 2020 Share Posted June 4, 2020 Did you search for parapet gable on the Home Designer website? Link to comment Share on other sites More sharing options...
SomeCallMeTim Posted June 4, 2020 Author Share Posted June 4, 2020 I am using Home Designer Pro 2021. Yes I searched first. The only result for parapet was a flat roof design, which is not what I am looking for. Link to comment Share on other sites More sharing options...
DavidJPotter Posted June 4, 2020 Share Posted June 4, 2020 In Pro and in Premier while in a cross section camera, one can click on an existing gable wall which then displays that walls "poly line" and its corner handles which can then be used to reshape that walls shape. This can only be done when you manually pull back the Roof plane poly-line's edges so they do not overhang that walls extents. With patience, one can then shape that wall in any configuration they wish. The only limiter is your own patience and willingness to obtain what you wish. DJP Link to comment Share on other sites More sharing options...
