MississippiMims Posted January 31, 2020 Share Posted January 31, 2020 In the attached plan, I am attempting to add a gable to the front of the house. The gable will rest on the front wall and will not extend the full length of the wall. I have tried the gable tool but have been unable to get the correct result. I'm not sure if its because of the porch having a separate roof plane or what. Any suggestions? Lancaster Plan.plan Link to comment Share on other sites More sharing options...
solver Posted January 31, 2020 Share Posted January 31, 2020 10 minutes ago, MississippiMims said: Any suggestions? The Gable/Roof Line tool only works with auto roofs. With manual roofs you draw in your own roof planes. What specifically are you having trouble doing? Link to comment Share on other sites More sharing options...
MississippiMims Posted January 31, 2020 Author Share Posted January 31, 2020 I had auto roofs turned off because I had to manually draw the porch roof and main roof as the customer originally wanted. They decided then that they wanted a small gable on the front of the house to add curb appeal. I tried using the gable tool to add this and was getting nothing. If I now turn on auto roofs, will my already constructed roof planes be altered? Link to comment Share on other sites More sharing options...
solver Posted January 31, 2020 Share Posted January 31, 2020 4 minutes ago, MississippiMims said: If I now turn on auto roofs, will my already constructed roof planes be altered? Yes Just use manual roofs to draw the new gable. Link to comment Share on other sites More sharing options...
MississippiMims Posted January 31, 2020 Author Share Posted January 31, 2020 I was trying that while waiting on a reply and was able to get the gable. Thank you. Now how do I create the opening in the main roof so it will be open to the attic? The customer wants a window in the gable. I told them that it would only open into the attic and will be purely decoration but I feel like they will still need to be able to access the window from the attic for any unforeseen maintenance. Link to comment Share on other sites More sharing options...
MississippiMims Posted January 31, 2020 Author Share Posted January 31, 2020 Also it did not generate the gable wall. How did you generate the gable in your example? Link to comment Share on other sites More sharing options...
DavidJPotter Posted January 31, 2020 Share Posted January 31, 2020 Please what this You Tube video I made using your plan file: https://youtu.be/fb1pbbDgXYc DJP Link to comment Share on other sites More sharing options...
MississippiMims Posted January 31, 2020 Author Share Posted January 31, 2020 Thank you David. That was an excellent tutorial. I was able to figure out the large gable walls as you have shown. The gable wall in question however is a smaller gable on the front of the house. I realize the front is not easily identifiable because I have not installed doors and windows yet. I have added a small gable as shown by Eric's example a few posts back. The opening I'm trying to create is through the larger roof plane underneath; almost like a dormer. Link to comment Share on other sites More sharing options...
MississippiMims Posted January 31, 2020 Author Share Posted January 31, 2020 I have attacked the plan as it stands now. Still can't figure out why I can't generate a gable wall on the front. Lancaster Plan.plan Link to comment Share on other sites More sharing options...
DavidJPotter Posted January 31, 2020 Share Posted January 31, 2020 OK, but the software is not pre-programmed to allow placing a skylight in a roof plane that is underneath two gable roof planes, so I would recommend placing a "Ceiling hole" as shown in my prior tutorial and fill in the sides in with soffits. DJP Link to comment Share on other sites More sharing options...
DavidJPotter Posted January 31, 2020 Share Posted January 31, 2020 1 minute ago, MississippiMims said: Still can't figure out why I can't generate a gable wall on the front. Walls show respect to the edges of roof planes, if the wall is on top of a roof plane it will have to be marked "Roof cuts bottom" in its wall specification dialog-roof tab or you must manually make sure that your gable roof planes overhang the top of that wall and that roof planes are not underneath its bottom (from the porch). DJP Link to comment Share on other sites More sharing options...
MississippiMims Posted January 31, 2020 Author Share Posted January 31, 2020 "Roof cuts wall at bottom" worked. Thank you so much for your time. Link to comment Share on other sites More sharing options...
MississippiMims Posted January 31, 2020 Author Share Posted January 31, 2020 Well, It was on there for a minute. It has now disappeared. Link to comment Share on other sites More sharing options...
DavidJPotter Posted January 31, 2020 Share Posted January 31, 2020 If the wall marked "Roof cuts wall at bottom" is not fully on top of the porch roof plane if will "disappear", it is pre-programmed and knowing that it is on you to get it right. DJP Link to comment Share on other sites More sharing options...
MississippiMims Posted January 31, 2020 Author Share Posted January 31, 2020 I'm sorry I'm not getting this quickly. The gable wall still needs to line up over the front wall of the house for framing purposes. Lancaster Plan.plan Link to comment Share on other sites More sharing options...
solver Posted February 1, 2020 Share Posted February 1, 2020 A not very good video ... Watch on YouTube: http://youtu.be/5jAD-OvdiOo?hd=1 Link to comment Share on other sites More sharing options...
solver Posted February 1, 2020 Share Posted February 1, 2020 Link to comment Share on other sites More sharing options...
MississippiMims Posted February 2, 2020 Author Share Posted February 2, 2020 That was a good video. I will admit I didn't know there were Youtube videos for Chief Architect. I had only watched the tutorials from the video help section of the website. Pulling the porch roof back from under the wall worked. I'm not sure how all of the breaks were added to my manually built roof planes and therefor I am not good at cleaning them up. I will take some time this week to try and learn more about manual roof building from Youtube. Thank you so much for your time and help. Link to comment Share on other sites More sharing options...
solver Posted February 2, 2020 Share Posted February 2, 2020 57 minutes ago, MississippiMims said: manual roof building from Youtube There are a couple of good roof videos -- search for advanced roof. Manual roofs take practice. When I started I probably drew 100 test plans with different configurations and roofs. Understanding auto roofs is also helpful. I'll almost always start with auto working in a Perspective Full Overview so I see the changes immediately. Then switch to manual if needed. I have some roof videos on my YouTube channel too. David Potter has a bunch also. Link to comment Share on other sites More sharing options...
