Head Clearance on Stairs
Westhousing
Do a section cut through the stairs. Then you can manually dimension from the tread to the opening above, as long as you have created a stairwell. I find the "point to point" measuring works best, especially if you draw a line from the nose of each tread in the area you need to measure.
