Foundation changes
Hammer7
You circled a rather wide area of your plan image, so as Eric said, it is unclear exactly what you are asking. Generally speaking "yes" you can raise or lower just about anything in a ".plan" file (Roofs, ceilings, floors, foundations, foundation walls, and footings or just about any other object or symbol there is). These changes can be made manually or via dialog boxes or mouse-direct-select-drag.
What, exactly do you wish to do, please.
I forgot to ask -- please post images (screen captures) when appropriate as they show directly in the forum and don't require a download and running a program to view.
9 minutes ago, Hammer7 said:
there is a 4' crawl space in the area that I circled and I want to change this in just this area only.
Yes it can be changed -- changed to what?
I'm trying to change it from full height to 4'crawl space and cannot find the window under "general" or "structure" after I select the wall and open the item?  I'm a bit rusty and trying to shake off the cobwebs while I get back into using the program on a daily basis.  I'm trying to figure out how to send screen shots too?
